Missed call notifications not syncing up on multiple phones/ 1 extension
Valentin Fernandez
I was testing a setup with two phones on the same extension to see how they would comport themselves: (dnd, voicemail, etc.)
Both those mentioned seems to work fine but for missed calls, when you acknowledge/delete the call it on one of the phones it doesn't propagate it to the other phone as it does for voicemail.
The phones used in this case are a Yealink T48S and a T46S
Unlike when retrieving a voicemail, and a MWI cancel is sent out to all extensions , I'm not certain that the same sort of thing happens with a "missed call" display on each set. That, I believe is local to each set and would have to be deleted individually.
Someone else may end up "correcting" me.
Reactions: YiannisH_3CX
That is exactly right. Missed calls are local to each set so you need to delete the missed call individually on each IP phone
