Missed Call Report issue
nhathq
Dear All,
I am having an issue with missed call reporting. Below is the detail:
* Elastix 2.5 is running very well
* We have a ring group, including 3 extensions: 101, 102, 103
- if an inbound call which was ringing on 101, after 15 seconds, the call was redirected to 102 because no one pickup the call. And the report marked that it was 1 missed call for 101 although 102 answered the call
- if a call was ringing on 101, the guy on 102 picked up the call because no one was at the position of 101 extension, and the report also marked that it was 1 missed call for 101
Now I want to find out a solution to have exact result of call report. Please help me to solve this a.s.a.p.
Thank you.
Can anyone help me?
Is there anyone having the same situation like me? :cry:
This settings are on the sip phone, For example on main SIP phones ES290N have options in Phone settings->Features settings->Display missed calls on or off and also have If busy to forward on other local sip number .
Best regards,
Milan
Best regards,
Milan
I think you misunderstood what I mean. We still need to display missed call on the screen of IP Phone. I was stuck for the missed report of Elastix because the system counted the calls which are not MISSED as missed calls for an extension :cry:
Hi.
When i call a ring group and an extension answering this call, there's no missing call for the other extensions.
I made some tests this morning and no problem if you mean that this information is written in this applet.
For your information.
I'm using Elastix 2.5 up to date.
Sorry danardf,
I've had a wrong information. In fact, I did not create any ring group. All is call queue. For example, after the IVR, press 1 will redirect to queue group with below settings:
Do you have any advices ?
The last screenshot (because the maximum of 3 attachments):
And it's only now that you give us these details? :shock:
Tsss. :roll:
If you can give us more details about your issue like for example your report where you have this problem?
There's too many ways for making reports With Elastix.
You joke so!
danardf said:
You joke so!
Honestly, I don't want to be joking. I'm not a specialist of VoIP so I had a wrong expression :cry:
After a deep research, I realize that I had a big mistake. I did the search from the "CDR Reports" of FreePBX and that's the wrong reports.
The exact way is export from Elastix like this: Elastix menu --> Reports --> Missed Calls
And now the result of report is fine. Thank you so much danardf. I will come back and ask for your help if having further more questions. Have a nice day.
OK.
You may use some documents like Elastix Easy written by Haamed.
It's based on Elastix 2.x
danardf said:
OK.
Hi danardf,
I was wrong again. The report from "Missed Calls" as above is not correct. I've just tried with some report as below:
* Missed call report for extension 131 from Elastix menu:
And I was so surprised that there was no missed calls on 09 October :shock: so I made a search from CDR Reports as below:
I don't understand why. Please help me :cry:
Your Elastix server has been updated?
Below is the details of packet version:
Code:
Name 	Package Name 	Version 	Release
Kernel
  	Linux(x86_64) 	2.6.18 	410.el5
Elastix
  	elastix 	2.5.0 	1
  	elastix-a2billing 	2.1.0 	1.gita40e37fefef7ab85999d04298b6e582b41930e7e
  	elastix-a2billing-callback_daemon 	2.1.0 	1.gita40e37fefef7ab85999d04298b6e582b41930e7e
  	elastix-addons 	2.5.0 	6
  	elastix-agenda 	2.5.0 	3
  	elastix-asterisk-sounds 	1.2.3 	1
  	elastix-email_admin 	2.5.0 	4
  	elastix-endpointconfig2 	2.5.0 	5
  	elastix-extras 	2.5.0 	1
  	elastix-fax 	2.5.0 	3
  	elastix-firstboot 	2.5.0 	3
  	elastix-framework 	2.5.0 	13
  	elastix-im 	2.5.0 	1
  	elastix-my_extension 	2.5.0 	1
  	elastix-pbx 	2.5.0 	6
  	elastix-portknock 	0.0.1 	0
  	elastix-reports 	2.5.0 	5
  	elastix-security 	2.5.0 	3
  	elastix-system 	2.5.0 	4
RoundCubeMail
  	RoundCubeMail 	0.3.1 	12
Mail
  	postfix 	2.3.3 	7.el5
  	cyrus-imapd 	2.3.7 	16.el5_11
IM
  	openfire 	3.7.1 	1
FreePBX
  	freePBX 	2.11.0 	24
Asterisk
  	asterisk 	11.21.0 	0
  	asterisk-perl 	1.03 	0
  	asterisk-addons 	11.21.0 	0
FAX
  	hylafax 	4.3.11 	1rhel5
  	iaxmodem 	1.2.0 	2
DRIVERS
  	dahdi 	2.10.2 	0
  	rhino 	0.99.7 	0
  	wanpipe-util 	7.0.14 	0
I never said to give me the version but just ask if you've made a Elastix update. So, yes or no.
Here i can say; no. Then do it.
Compare with my version up to date so!
Kernel
Linux(x86_64)-2.6.18-412.el5.centos.plus
Elastix
elastix-2.5.0-1
elastix-a2billing-2.1.0-1.gita40e37fefef7ab85999d04298b6e582b41930e7e
elastix-a2billing-callback_daemon-2.1.0-1.gita40e37fefef7ab85999d04298b6e582b41930e7e
elastix-addons-2.5.0-6
elastix-agenda-2.5.0-3
elastix-asterisk-sounds-1.2.3-1
elastix-callcenter-2.2.0-17
elastix-developer-2.3.0-5
elastix-distributed_dialplan-2.3.0-1
elastix-email_admin-2.5.0-6
elastix-endpointconfig2-2.5.0-5
elastix-extras-2.5.0-1
elastix-fax-2.5.0-3
elastix-firstboot-2.5.0-3
elastix-framework-2.5.0-17
elastix-im-2.5.0-1
elastix-my_extension-2.5.0-1
elastix-pbx-2.5.0-9
elastix-portknock-0.0.1-0
elastix-reports-2.5.0-8
elastix-roomx-2.0-113
elastix-security-2.5.0-4
elastix-system-2.5.0-6
RoundCubeMail
RoundCubeMail-0.3.1-12
Mail
postfix-2.3.3-7.0.1.el5.centos
cyrus-imapd-2.3.7-16.el5_11
IM
openfire-3.7.1-2
FreePBX
freePBX-2.11.0-25
Asterisk
asterisk-11.21.0-0
asterisk-perl-1.03-0
asterisk-addons-11.21.0-0
FAX
hylafax-4.3.11-1rhel5
iaxmodem-1.2.0-2
DRIVERS
dahdi-2.10.2-0
rhino-0.99.7-0
wanpipe-util-7.0.14-0
Next, if the problem still there, then post your issue in elastix bugs report. : http://bugs.elastix.org/
Hi danardf,
I updated to the latest version of 2.5 as your suggestion. The missed call report is still wrong and the worst thing is now I'm having a new error for my system after the update as below:
Almost the recording are in the status "Recording missing". The record folder is still there, there is no changes. I also check some tables of asterisk database like: recordings, callrecording, callrecording_module, etc... and they are OK. Please help me to solve this :(
- I've checked the recording folder, for example: at 17:35:11 on 12th October 2016, the data of outgoing call for extension 151 still exists in there, but the Call recordings via PBX show "Recording missing".
- I've made an inbound call from my mobile phone to the Elastix system, there is no recording data in the Call Recordings as it should be
- End-users made some outgoing calls (a few minutes ago) and the system show "Recording missing" in the Call Recordings, although the recording file is there...
I will try to restart the system and pray :(
I don't work in the dev team for Elastix excepted RoomX or some own modules made in Franck.
Like i said, if you think it's a bug, you have to send your issue in elastix bug report.
If somebody must to fix this issue, it's the support team.
I've no solution for your issue. Perhaps I think at a bug indeed.
RRusev
