Solved Mobile numer not accepted
Martijn Goudkamp
Hi! Am using the Cloud version of 3CX and it's working great. However, I cannot register the following mobile number from Italy inside an exention: 3395777777‬
Apparently, too many sevens (as 777 is reserved for IVR, I guess the number is not accepted).
How do I circumvent this ?
Hello @Martijn Goudkamp
Try to delete and type the number in again in case something else is included when you copy and paste the number. The PBX should accept the number
I feel so stupid now... works perfectly. Thank you!
Glad to see the issue has been resolved. It happened to me as well is the past :)
Mr_IT
