Mobile phone Australia to VOIP trunk
manish@infosmartaustralia
Hi All,
Anyone connected Mobile phone (Virtual) for techsupport /etc directly to any sip trunk on 3CX trunk. Any SIP provider in Australia offering this.
I am not taking about call forwarding to another number. Direct Mobile > SIP trunk > VOIP Extension.
Any one .really helpful.
Sorry , What is your need , where is your question?
connect mobile phone number in australia to sip trunk directly.
OK, so I'm not the guy for this one :(
It sounds as if you're are looking for a mobile network gateway. While GSM models are quite common, you would have to look for a model that works with the particular network you wish to use.
Many sites have these available...
https://www.amazon.com.au/Gateway-GOIP-1-Support-AsteriskTrixbox3CXSIP-ServerVoip/dp/B00L11NO5U
https://www.telephonesonline.com.au/gsm-gateway/
https://www.voip-info.org/australia/
Again...(and I can't state this enough), confirm that the model that you are considering will work with the provider you plan to use, as different providers can be using different technologies. It is probably not going to be officially supported by 3CX, which means you must be prepared to manually provision it.
You could also use a mobile to analogue gateway (the type of wireless box that you'd plug a standard telephone in to), and then connect that to 3CX using a PSTN type Gateway (many of which are supported), with a phone cord.
hughesdouglas
