Modify 3CX sample Call Processing Script for PIN to play custom prompt
yules67
Since custom DTMF IVR are not available in V20 (sad), I want to use the 3CX sample Call Processing Script for PIN with a custom promp instead of Text to Speech.
I've change the line :
C#:
await MyCall.PlayPrompt(null, new [] {"PLSENTER", "PIN", "THENPRESPND"}, PlayPromptOptions.ResetBufferAtStart|PlayPromptOptions.CancelPlaybackAtFirstChar);
with :
C#:
await MyCall.PlayPrompt(null, new [] {"/pathToProject/RequestPIN.wav"}, PlayPromptOptions.ResetBufferAtStart|PlayPromptOptions.CancelPlaybackAtFirstChar);
and the right prompt is played but in the same time the background music is played too.
I've tried to delete/change several part of the line where "SetBackgroundAudio" is mentioned but i can't get it right.
How to do that properly ?
Try this:
MyCall.SetBackgroundAudio(false, new string[] { });
Try this:
Good answer !
Good thing I taught you that, :rolleyes:
I see you're following my instructions well. xD
Okay okay, I admit, I didn't teach you anything lol.xD
I didn't even know that, but I'll take note. Thanks for sharing.
Good answer !
Haha, that's just a part of the C# code you can see in any CFD app, you just need to look carefully.
ARKC
