MOH and Parked Calls
MontNeph
MOH currently is set up with 4 wav files 0-3 and set to randomize playback. I'd like to replicate this for parked calls. However under call parking there is only one dropdown to select a single wav file. Is there a way to have the parked audio mimic the MOH set up?
In Music On Hold Settings set up a Playlist, then you can pick the playlist in the Parking and Conferencing settings areas.
Reactions: ChrisC_3CX
To add to what @SteveITS said, you can even have the .wav files play in a random order:
Silent_Guru
