MOH
Graham Hobson
Am using 15.5 3CX
I have tried to set up 2 recordings to be played one after the other but it just plays the first one in a loop. How do I get the system to play one after the other?
I also tried to put the 2 recordings into a playlist but then it started part way thru the first recording?
Any ideas?
Hello @Graham Hobson
Where did you set the 2 recordings? Are you using a queue or the general music on hold of the system?
Keep in mind that MOH plays in a loop so what your caller hears depends on where in the loop MOH happens to be when they call. It does not start at the beginning for each call.
Sorry for the delay
I put the 2 recordings in General MOH
I also put the playlist in Music On Hold Settings
That explains why the playlist seems to start part way through - thanks
i would recommend creating a playlist and using the playlist as the music on hold file. This way the files will play in order.
megalmazan
