monitoring tab not showing queue calls on 2.4.0!
hcqm
It looks like the monitoring cdr on Elastix carries some problems since a long time ago.
This time my version is 2.4.0 and asterisk 1.8.20 although it seems that still doesn't work on asterisk 11.5
As per this ticket issue: http://bugs.elastix.org/view.php?id=1593
That guy is still waiting for an answer since June 2013. I hope you don't find a skull here!
I mean I know someone would say.. come on its free!.. but hey! it has been 9 months now since then.
The problem in my case is as the subject says calls are not shown on monitoring tab for queue recordings (gsm format).
I checked the files are there with correct format and if I go to mysql I can see user-field is empty on queue calls, and not on normal outgoing calls. If this is an asterisk issue please help, I upgraded a copy on the server to asterisk version 11.5 and the problem persists.
Thanks anyone.
Kernel
Linux(x86_64)-2.6.18-348.1.1.el5
Elastix
elastix-2.4.0-1
elastix-portknock-0.0.1-0
elastix-agenda-2.4.0-1
elastix-email_admin-2.4.0-1
elastix-addons-2.4.0-1
elastix-fax-2.4.0-1
elastix-callcenter-2.2.0-5
elastix-firstboot-2.4.0-1
elastix-framework-2.4.0-1
elastix-reports-2.4.0-1
elastix-my_extension-2.4.0-1
elastix-extras-2.4.0-1
elastix-vtigercrm-5.2.1-7
elastix-system-2.4.0-1
elastix-security-2.4.0-1
elastix-im-2.4.0-1
elastix-a2billing-1.9.4-5
elastix-asterisk-sounds-1.2.3-1
elastix-pbx-2.4.0-1
RounCubeMail
RoundCubeMail-0.3.1-12
Mail
postfix-2.3.3-6.el5
cyrus-imapd-2.3.7-12.el5_7.2
IM
openfire-3.7.1-1
FreePBX
freePBX-2.8.1-16
Asterisk
asterisk-1.8.20.0-0
asterisk-perl-0.10-2
asterisk-addons-1.8.20.0-0
FAX
hylafax-4.3.10-2rhel5
iaxmodem-1.2.0-2
DRIVERS
dahdi-2.6.1-4
rhino-0.99.6-0.b2
wanpipe-util-3.5.28-0
Apollo Cloud
