Solved Move instance from AWS hosting to 3CX hosting
bevans9908
I created a trial instance on the free tier of AWS and would like to now move that instance to 3CX hosting. Is there any documentation on how I can complete the move? I know it may seem easier to just start from scratch but in my efforts to be thorough in testing, I built quite a bit of what will be the permanent config on the trial instance. I'm hoping I won't have to rebuild it all.
Any help would be greatly appreciated.
@bevans as a first step take a backup with license key and FQDN from your AWS machine.
Login to https://portal.3cx.com>> Click Reinstall from the top right corner and proceed as per following screenshot and deploy your machine.
on the first step it will as you to upload your backup also.
Awesome. I'll give it a try.
Thanks, @NikosT_3CX
Much appreciated!
Reactions: NikosT_3CX
@bevans9908 don’t forget to power off the AWS machine :)
Lol! Absolutely. A commonly overlooked step for sure!
Thanks, again @NikosT_3CX
GP Concepts
