Move the webclient dialer
elementelist
Hi all,
Is it possible to move the dialer in the webclient?
When calling with the webclient, the dialer pops up in front of the group selection.
Some users would like to select a group while they are in a call.
Thanks in advance.
As far as i know this has a fixed position in the webclient , if you install the windows client you can move the dialer around i beleive.
Reactions: PanagiotisL_3CX
@elementelist
As correctly mentioned from @JosIPVG the dialer in the Webclient is not moveable. Installing the Desktop app however allows you to position the dialer where you wish on your screen.
megalmazan
