MSSQL integration - internal calls logging
alex.filip
Hi, I need help regarding call forwarding to MSSQL database. The insert from the official 3CX documentation works, but internal calls are not being inserted, e.g., 000 -> 001. Only external calls (073664632@Number -> 001@Agent) are being inserted. Is there any variable for the internal number (the one making the call)?
Also, is there a variable for the name of the attachment being sent?
Thanks!
Internal calls are not included in the CRM integration. There's no way to change that.
You would need to create a custom integration. If you don't need to perform screen pops, then this could be a server-side service using the Call Control API.
Thank you for your response! I don't need to perform screen pops, just logging internal calls. Based on that we can do some other integrations for other systems.
You may want to use the reports or something like that, or the CDR, to read call data directly. @VoIPTools has an excellent Relay module for that.
How 3cx can insert to a (crm) mssql database?
You can use the CRM database integrations to send the call report to a db.
