Multi-Tenant incoming calls configuration
djuhnke
Is there a way to configure the callerID on the incoming calls so that if you have multiple DID's for multiple companies, I could at least know who is calling for which company.
For example if line 1 is DID 123-4567 for ABC company and line 2 is 345-6789 for XYZ company, when a call comes in I can see its for XYZ and know to answer that way.
Make sense?
Dan
Hi.
Yes, it's possible.
It's into the incoming route module, and set the CID name prefix.
Regards
Perfect. Thanks!
Re: Re:Multi-Tenant incoming calls configuration
I have an accont that takes inbound calls for different companies and what i do is a route the inbound calls do different queues and set up an announcement in each queue so when the agent picks up the phone will hear a recording that tells him what queue the call belongs to. Good luck!
what do you mean?
iamatlas
