Multi Tenant
BCS Tech
I need to convert an existing installation to a Multi Tenant installation. The current system is hosted at Digital Oceans. V20
Is there a set of instructions on the changes that need to be made for this. I see the instructions on how to set the system up for Multi Tenant when you are initially creating the site, but this site is existing.
Thanks.
Go to parameters and search for MCM.
Set it to 1.
Then limit_pickup_to_group to 1.
Just a reminder that this is beta software and not intended for production use yet. The last thing I would recommend is putting a bunch of production customers on the same beta version.
Reactions: MayurPatel
I found those two setting earlier and changed them. But after I make the change and even rebooted the system, I do not see when I go to the Department tab and create new one, the option to limit the extension numbers as shown in this link
https://www.3cx.com/docs/multi-tenant-configuration/
I am doing this testing on my one system.
What exactly did you do to enable multi tenant? Did you just add the XML or did you overwrite the information? I do not have the option of multi tenant in the system options on my test server
Search for MCM in the parameters, enable it then restart services
ARKC
