multiline tapi,installation error
hanstps
i get the following error when i try to install the multiline tapi plugin :
There is a problem with this Windows installer package. A script required for this install to complete could not be run. Contact your .....
(pc client = win8)
Hans
Below the contents of log file :
Code:
Action start 09:55:28: AddKeyValue.
MSI (c) (34!9C) [09:55:28:594]: PROPERTY CHANGE: Adding HttpPostCollectData property. Its value is 'VersionNT64;MsiNTProductType;ProductVersion;WindowsBuild;VersionNT;PLUGINSELECTED;UserLanguageID'.
MSI (c) (34!9C) [09:55:28:594]: PROPERTY CHANGE: Adding HttpPostSuppressSpawnMsgBox property. Its value is '1'.
MSI (c) (34!9C) [09:55:28:594]: PROPERTY CHANGE: Adding HttpPostUrl property. Its value is 'http://www.3cx.com/collect_db_3cxplugins.php'.
MSI (c) (34!9C) [09:55:28:676]: PROPERTY CHANGE: Adding HttpPostServerResponseCode property. Its value is '200'.
MSI (c) (34!9C) [09:55:28:676]: PROPERTY CHANGE: Adding HttpPostServerResponse property. Its value is '
MSI (c) (34!9C) [09:55:28:676]: PROPERTY CHANGE: Deleting HttpPostCollectData property. Its current value is 'VersionNT64;MsiNTProductType;ProductVersion;WindowsBuild;VersionNT;PLUGINSELECTED;UserLanguageID'.
MSI (c) (34!9C) [09:55:28:676]: PROPERTY CHANGE: Deleting HttpPostSuppressSpawnMsgBox property. Its current value is '1'.
MSI (c) (34!9C) [09:55:28:676]: PROPERTY CHANGE: Deleting HttpPostUrl property. Its current value is 'http://www.3cx.com/collect_db_3cxplugins.php'.
Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor.  Custom action AddKeyValue script error -2146828235, Erreur d'exécution Microsoft VBScript: Fichier introuvable Line 12, Column 1,
Action ended 09:55:28: SendCollectedData. Return value 0.
MSI (c) (34:DC) [09:55:30:798]: Product: 3CX Plugins -- Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor.  Custom action AddKeyValue script error -2146828235, Erreur d'exécution Microsoft VBScript: Fichier introuvable Line 12, Column 1,
Action ended 09:55:30: AddKeyValue. Return value 3.
MSI (c) (34:0C) [09:55:30:798]: Doing action: FatalError
Action 09:55:30: FatalError.
Action start 09:55:30: FatalError.
Action ended 09:55:34: FatalError. Return value 1.
MSI (c) (34:0C) [09:55:34:831]: Doing action: AI_SHOW_LOG
Action 09:55:34: AI_SHOW_LOG.
Action start 09:55:34: AI_SHOW_LOG.
MSI (c) (34:88) [09:55:34:847]: Invoking remote custom action. DLL: C:\Users\CAB2\AppData\Local\Temp\MSIDB40.tmp, Entrypoint: LaunchLogFile
Action ended 09:55:34: AI_SHOW_LOG. Return value 1.
MSI (c) (34:0C) [09:55:34:863]: Doing action: FatalError
Action 09:55:34: FatalError.
Action start 09:55:34: FatalError.
MSI (c) (34:0C) [09:55:34:863]: Doing action: AI_CleanPrereq
Action 09:55:34: AI_CleanPrereq.
Hello @hanstps
Please try disabling any antivirus software currently running on the PC and try again. Also make sure that windows is up to date and no updates are pending.
Make sure that you have MS VC++ 2010 redistribuables x64 installed on the PC. You could also try re-installing them to exclude that as an issue.
Finally try to re-download the installer in case something was corrupted during the download.
https://www.3cx.com/docs/installing-multi-line-tapi/
Hello @hanstps,
Please ensure that you're installing this in a 64 bits operating system, as the Multiline TAPI service provider is not available for 32 bits.
johnblackwood1
