Multiple Dect W60B at different locations
Sheppy
Hi All
I am trying to add multiple Yaelink DECT phones to 3cx V20.0 (Build 715 Release)
i am only able to add one W60B base and successfully add the handsets
Any additional bases will not register but will provison the base. i will add that the additional bases are at different locations (not sure if that matters)
please could i get some help in understanding how to allow multiple bases to register from different locations.
i have gone into user options and unchecked to "Block remote non-tunnel connections"
please help
thanks
Sheppy
Don't remove the block remote. Security issue.
Have you got a SBC or a router phone at the remote locations?.
no SBC or Router phone at remote location...i already have one Dect W60B base connected and registered but it wont let me connect another...
You need to use an SBC or routphone. STUN isnt supported anymore.
Reactions: JohnS_3CX
Finatra.us
