- Joined
- Jun 9, 2021
- Messages
- 10
- Reaction score
- 2
Hi everyone,
I'm currently implementing an on-prem 3CX server for my organization. I have most of the functionality working, however I'd like to have multiple DIDs run through a single trunk if possible.
My upstream provider is Telnyx. Their server uses the phone numbers I have purchased as the username to authenticate for outbound calls (e.g. [email protected])
My issue is regarding the correct method to make my SIP trunk transparently pass the extension's phone number as the user. As per a separate a forum post, I set the "From: User Part" to "OutboundCallerID" on my trunk. To my understanding, this should cause the system to pull the outbound caller ID (in this case the phone number) set in the individual extension as the user to authenticate against the Telnyx PoP.
However, this is not what occurs. Rather, my 3CX install always passes my test number as the user and ignores the outbound called ID I have set for the extension. The only way I am able to make the system use the second number is when I set the trunk's "From: User Part" field to a custom value containing the number.
