multiple instances of 3cx PBX?
nobody
I have to install a second PBX on a site, since a second MOH is needed. Just to make sure my information is correct:
The glorious days of more the one instance of the PBX on one host are gone since the appearance of v15, I have to create one VM per PBX. Also, I need another external IP per PBX.
is that correct?
Or at least: If I connect those two pbx together, could I use the trunks of the first instance for making and receiving calls so that I dont need another external IP Address? How about connecting external Phones, android or Hardware phones with STUN?
To make your life easy, you need one 3CX server per installation and one IP per 3CX installation.
Note : if you use queues you can select your MOH
Hello @nobody
As mentioned you need one public IP per 3CX installation. Why do you need a second MOH exactly? Someone may have a workaround if you explain what is the desired functionality.
I tried to correct my typos, but there is no edit button (only report, quote, reply). I would expect, a post is editable until a reply is made?
Personally i cannot think of a different way to implement this. If you need a second PBX then i would recommend going with a cloud solution for the small company and bridge them.
I believe you can edit your post for a certain time period after the post was made. See if you can edit a reply after you posted it and let me know.
Thank you Yiannish,
Regarding autoprovisioning if I have two phone systems in one subnet. Is there anything I have to think of or take additional care for?
PS: edit seems indeed dependent on a timer. I can logout and login, the edit button will be there - but as I noted yesterday, it is not present after a time of XX, even if there is no reply.
Once a phone gets provisioned to a PBX it should only contact that PBX.
Thank you for confirming. This is the intended behaviour.
K7oR0x
