Multiple integrations on multi-company instance
angelm
SOHO User
Hi all
I have a 4SC pro edition with integration to Zoho.
Ive been told that 4SC pro will no longer support and needs 4SC enterprise. i also have a 16SC pro with multi-company enabled hosting 2 clients. Can i instead add my 4sc client onto my 16SC pro multi-company and do the integration per company/department?
nb: the clients on my 16sc pro do not have or desire any integrations.
Hello, CRM integration is not compatible with multi company mode.
Reactions: angelm
Can you confirm if 3cx forcing us from 4SC pro to 4SC Ent to use CRM integration?
Lorraine O'Sullivan
