Multiple pbxexpress vms in a single Azure tenant?
fbremote
Hi - if for various reasons we wanted multiple 3cx installations in distinct resource groups, will the pbxexpress tool allow that? I'm afraid to nuke our existing install.
Thanks,
Mike
No.
We do this for a couple of people. My advice is to manually spin up a Debian instance, and install manually for each client.
We have scripted it.
Got it, thank you.
you can have many instances in one Directory. Within this Directory a Resource Group call PBXexpress is created in which all Instances will be created. Selecting another RG is not supported.
Stefan
Did something change in the script? The last time I tried this it was when you first released this and that didn't work for me at all.
you might delete this again, as we need to have a fixed property to create this (and I dont know why it is needed) storage account. And this must be unique and created via API and you cannot have more then one per RG. Its a bit messy in this area in Azure... I have no way of addressing it with the current API version.
Can't seem to delete. But thank you for explaining!
Reactions: StefanW
fransisco
