Multiple processes - nginx.exe, PostgreSQL Server, Console Windows Host - normal?
dennisc
Forum User
We're on 3CX version 18.0.6.908 and on Windows 2016, when we look at Task Manager, under Processes we see 9 entries for nginx.exe, 16 entries for PostgreSQL Server, and under Windows Processes we have 11 entries for Console Window Host. Is this normal?
Hi @dennisc as first step you should update your system to the last version 18.0.8.939
Also the server must be dedicated to the 3CX without third party softwares installed. Verify that the 3CX host machine is not configured as a server for DNS, DHCP, MS SharePoint, Exchange, SQL or any other network-based service(s).
Additionally, to my colleague's reply, a 3CX install will present multiple processes for the same services, which is normal.
mazet
