Multiple Sites VPN
Cables
Forum User
Hello
I am planning on setting up a VPN for a Company with 20 branch offices. We will require Dual Wan Routers for Head Office and branch offices for internet failover.
Any recommended Router? Note we will setup VPN through this router as well.
Your help appreciated
This sounds like more of a networking question.
I would look in your area for a good MSP to help you setup something like this.
pfsense, the vpn will be a piece of cake, ids and ad not so much.
edgewater, vpn piece of cake voip options are unlimited, ad and ids are very hard.
meraki, if you are doing it on your own, this maybe the best option.
good luck.
@3cxnub thank you. What Router (Make and Model) would you recommend for using at Head office and what for the 2o Branch Offices. Each office will be using 5-10 voip phones. I assume the branches would require a smaller module than that at Head Office
You should talk with sales @ netgate https://www.netgate.com/support/ it is going to come down to what kind of isp you have access to, rules for failover, qos, vpn, your exp and what the vpn is going to do, is this just for 3cx or more traffic etc.
Reactions: gorbros
Thank you. Appreciate it
tohoken1
