Multisite DECT System
DelaSim
Hi, I have a customer who asks me to be able to move between his production sites using the same cordless phone at multiple sites. I thought about providing him with a hosted 3cx PBX. As regards DECT phones, the only solution that seems to me to be able to do this operation natively is the W90 base using VIM. Is this solution supported by 3cx?
Do you have any other suggestions you can give me?
With different companies/extensions?
If one company, with 3CX it would be easier to use the mobile app and his phone would ring anywhere.
Same company, same extension. Unfortunately not all employees have a company cell phone, so 3cx app is not a viable option.
Dear @DelaSim
I don't use yealink multicell dect so i can't answer for w90.
You can do this using snom m900 multicell with p2p sync, all the sites should be linked with a s2s VPN with the "main" site. Let me know if you want more details !
@DelaSim
Hi there.
Kindly be informed that 3CX Hosting, do support DECT W90DM and you will be able to add that dect there.
Since you can get the trial key, do that and see how it works out for you.
DejanMDS
