My subscription is soon coming to an end.
atlantisegidek
Forum User
My English is weak, sorry about that. I hope I can explain.
I have been using 3CX for almost a year now and my subscription is soon coming to an end. I found the renewal prices. I want additional 5 years. But the payment is 1730.00 £.
Too many.
But there is a situation for this.
"However, if you only need 3CX for up to 8 simultaneous calls and the standard feature set is enough for you, then you do not need to do anything - your PBX will be converted to an 8 SC Standard edition, automatically and at no charge."
Is the standard enough for me?
User: 50 people.
What are your suggestions?
Thank you.
It depends on how you use the system, and how much. You can use our pricing calculator and compare the difference in price accordingly: https://www.3cx.com/ordering/pricing/
In case the 8SC is not enough for you, there is always the ability to upgrade it whenever you want.
Also in Settings > Email > Notifications you can tick "License limit is reached" and you will get an email if the limit is reached often.
Too many.
User: 50 people.
Thank you.
Look at the features you lose going from Pro to Std. If you dont use the Pro features you lose, and you can get away with not having > 8 calls at once then std will be fine.
After I gave my license to the company, I can't get offers from this site.
What do mean ? you sold a company in which you had a 3cx ? that's it?
if so and well understood, and you change licence owner in 3cx portal, then you are no more considered as a 3cx customer so it's normal behavior you are no more able to connect to portal
travislogixal
