prb1412 Premier Customer Joined Feb 8, 2023 Messages 44 Reaction score 5 Dec 22, 2023 #1 Is there a way I can spin up another instance and restore the backup to that machine in order to run a report. Then shut it back off? I do not want to loose my current instance!
Evolute IT 3CX MVP Gold Partner Advanced Certified Joined Feb 6, 2018 Messages 11,249 Reaction score 7,113 Dec 22, 2023 #2 Why would you not run the report on your main instance? The second you setup a second one, it will be a problem for the license.
prb1412 Premier Customer Joined Feb 8, 2023 Messages 44 Reaction score 5 Dec 22, 2023 #3 The data is no longer on my instance. I need data > 6 months old which is only on backup.
prb1412 Premier Customer Joined Feb 8, 2023 Messages 44 Reaction score 5 Dec 22, 2023 #4 Is there a file I can restore that would provide call log data? i.e a csv?
