Solved Need to transfer a call from one device to another but under same extension
apitsos
SOHO User
If someone has more than one device registered with the same extension (eg. IP phone and softphone), is there a way to transfer a call from the softphone to the IP phone and the other way around?
you can go through the Parking lot
Hi paurus!
Thank you for your reply. How can I do that, please? Is there such a function at the 3CX softphones?
Reactions: apitsos
Reactions: paurus
Hi paurus!
This article helped me a lot. I managed to park a call and retrieve it from another device. That procedure covers the need, requested by our client.
I would like to thank you for your assistance. It’s much appreciated.
I'm glad I was able to help you. Good luck in mastering the wonderful 3CX system!
  • Love
Reactions: apitsos
Yes, easy.
do a blind transfer to yourself, pick up on the other device.
Reactions: apitsos
Yes, easy.
Before you do this, don't forget to enable the "accept more than one call"setting. Although some users don't like it. Your mobile phone will ring when you speak on your work phone.
Not required to tick this option.
I have a "busy" signal without this option.
odd, works fine for me
Wow! That works also...
Yes, easy.
But I had to enable this option:
Otherwise it goes to the Voicemail.
Anyway, Thanks a lot for the extra option. Now we have two ways to that. I think the client will be more than happy when I will explain it to him.
Thanks a lot both of you!
