Neogate ta400 Connecting to 3CX Cloud
Muhammad Al Baloushi
Hello Guys,
i have purchased Yeaster Neogate TA400 VoIP Gateway and trying to connect my local Lines to my 3CX Cloud PBX but unfortunately I have followed below tutorial but i am a bit confused it's not working and correct me if the solution is possible or not,
My Voip gateway is here in my office and i don't have static IP to connect it to my 3cx Cloud, i have signed up for an account with no-ip and in my gateway i had an option DDNS where i added my login details its showing the DDNS is running but i am unable to connect it to pbx and nor i am unable to ping the host ouside.
overall is it possible to connect your VOIP Gateway to Cloud PBX through DDNS (Through No-Ip)
Suggest a Tutorial.
thanks You.
cur_cb
