.Net CRM Client Plugin
Fatai Okeleji
Hello, I did an integration with the MyPhoneCrmIntegration.dll windows plugin and I discovered that the call status (OnCallStatusChanged) event does not return the originator parameter, is there any workaround for this?
What information do you need?
I'm not sure I follow what you are looking for, but if you are looking for the extension logged into 3CX phone, use this:
private async void callHandler_OnCallStatusChanged(object sender, CallStatus callInfo)
IExtensionInfo extensionInfo = sender as IExtensionInfo;
string myExtension = extensionInfo.Number
Thank you,
But the scenario is, there is an incoming call. The above event is triggered.
I need the callInfo.originator and callInfo.originatorName parameters, which should be the caller's extension. They both come back as null.
To reiterate
private void callHandler_OnCallStatusChanged(object sender, MyPhonePlugins.CallStatus callStatus)
string originator = callStatus.originator;
string originatorName = callStatus.originatorName;
They both come back null
callInfo. OtherPartyName
callInfo. OtherPartyNumber
Sorry about the space between the "." and the "O". The forum keeps replacing with a happy face.
These should not be blank unless your carrier is not passing caller ID information
Thank you, I use the 3cx softphone and a server installed on my machine.
Who is my carrier in this case?
To come back to this, both of those fields return the presently logged in extension, not the originator of the call in an incoming call scenario.
costionofrei
