Network in Settings
Wael
Hello, I'm unable to find 'NETWORK' in 'Settings' from management console. I'm on the latest version.
As mentionned here: Are you using the main Admin user? It should show "A" in the top-right.
Hi @Wael,
Hosted instances do not give you the network tab in Settings. There are requirements mentioned here: https://www.3cx.com/docs/switch-hosted-pbx/
Requirements for 3CX-hosted instances:
  • You must use a supported, register based SIP trunk. See how to check.
  • You can not use CFD (Call Flow Designer) apps.
  • IP phones must be run behind the 3CX SBC.
  • FXO and ISDN gateways are not supported.
  • No Remote system-level (e.g. SSH) or web terminal access to the machine.
  • Network settings, Instance Manager, Parameters, License Key, Failover, custom IP-phone templates, scriptable IVRs, and Path and Quota for Recordings or Voice mail can not be changed.
Tech_Support
