New Android Beta: Telecom API for BT & Handsfree
  • Thread starter Thread starter KyriakosP
  • Start date Start date
KyriakosP
In this new beta, we’ve switched on telecom API by default. This means you can use Bluetooth headsets and also hands-free for the car. You no longer need to switch on the telecom API to enable this integration. The telecom API is the standard on Android for integration with headsets and hands-free. However, on some older phones, the telecom API c...
Cool! this are good news. :)
When is the new app going to be available in the playstore?
@alainarnold
The Beta version can already be downloaded, just follow the instructions in the Blog Post.
If you are referring to the official release it should be just around the corner!
@alainarnold
Hi Chris,
thx for your reply. yes im talking about the official version. but like you said, it should be just around the corner :)
Reactions: ChrisC_3CX
since this update my android rings, but no longer pops up a way for me to answer the call. i have to manually open 3cx app and hope i do it fast enough to answer the call.
Is your PBX up-to-date? The push system has been changed in the background to enhance the speed and reliability. That was explained in the latest V16 release post.
yeah fully patched. it's the android client beta that i'm on now that stopped ringing. they reached out direct for me to try an update so i'll load it and see if it fixes the cell phone application.
I'm having the same issue. Fully up to date 3cx system on lynix and a Samsung Galaxy s21+ phone running the new bata release. The app rings but nothing comes up to allow me to answer the call
same here. I'm not blaming anyone, it is a beta version, no problem. So just to confirming for development team ;)
@network51 @Phone systems NZ @weimerd Thanks for reporting, indeed it's an issue with the latest released version on some devices.
A fix is on the way we should have another release tomorrow.
Reactions: weimerd and N_G
To stay on feedback for latest beta release for Android , yesterday i got it blinking connected/unconnected and impossible to stop this, I needed to stop app and restart it to have it doing normal, for now no more weird behavior.
Jeremy Hofex
