New Firmware Release for Fanvil X210-V2
Pierre_3CX
Staff member
3CX Support
Firmware update fixing key security issues in Fanvil firmware.​
A new interop firmware update (v2.12.22.2) for the Fanvil X210-V2 IP phone was provided by Fanvil. According to Fanvil, this firmware includes important security fixes. Following successful interop verification, the update has been made available. For further details, pleas...
To all resellers and customers who have these phones - Its important to install this update!
Hello @Benedikt Machens ,
This is indeed for the X210-V2 only.
For X210i-V2 you can talk with Fanvil directly if you wish to get an updated firmware and you can use the Unsupported firmware upload option as per below:
  • In Phones/Options enable the use of unsupported firmware.
  • In Phones/Firmwares upload the new firmware making sure to select the correct model.
  • Reboot the device.
  • You should be able to disable the Unsupported firmware option after the phone updates.
Reactions: accentlogic and N_G
stauag
