New Grandstream GXP-21xx firmware .108 fixes 3cx provisioning
Leon Zetekoff
GS released last week (?) new firmware to fix provisioning with 3cx. Can this be uploaded to the servers for provisioning please? I can confirm issues with provisioning GXP-21xx with the .102 firmware.
Thanks leon
I believe only the most recent tested firmware is put in the 3CX list so you are at the mercy of when they are able to get around to properly testing it.
That being said, if you look around there are workarounds to get your 3CX install to deploy a different firmware to your phones than the recommended one.
Hi @Lee Cramman yes thanks I do beta testing on various GS products so I am familiar with loading up new firmwares. I posted that to see if we can move it along on the "supported" side :-)
Reactions: Lee Cramman
They are thorough with the QC process. I have had conversations with NG on this in the past.
It will be out when they are confident with the build.
Hi @craigreilly
Thanks for the update much appreciated. Leon
megalmazan
