New HubSpot Developer Account
deka
Hello, seems the 3CX documentation for integrating 3CX with HubSpot was written before HubSpot's August 2025 Developer Account Update. Does anyone have instructions on how 3CX can be integrated with HubSpot given the new way HubSpot allows development access? Or, does 3CX have a native HubSpot App like AirCall does?
I think you can create a private app in Hubspot, can't you?
Thanks for the response. I am sure it is possible but the integration guide in 3CX is very different than the new developer portal for hubspot. Hubspot has moved to using Hubspot CLI and is requiring Node.js and NPM. There does not appear to be the GUI "Create an APP" any longer.
There is. Just bypass their "projects" page. The My Apps is still there. Check the navigation.
