New in V20 - Call Processing Scripts
Because you cannot. Those scripts are executed wayyyy before an agent is called, so you cannot get the agent. The script instance is disposed before that.
@omnicasa - if you want to track a call and make changes in realtime you need the new web based Call API in update 4
Thank you for supporting!!!
This means that we must use Call FlowApps to track a call as old version.
Is this right?
No problem - no its a new API which allows much more control. no need for CFD. That's a very limited way anyway
Jeremy Hofex
