Solved New Install - System Owner Information
aaronl
Platinum Partner
Hi All,
I am just looking to find out if there is a way to define the System Owner details and extension number during the install process? I have found that it is always using Extension 1000 and a random name.
For example the latest one I setup was an “On Premise” setup and I put in all the customers details against the license in the 3CX portal (portal.3cx.com). I copied the URL and put it into the 3CX wizard and the only information it pulled across was the email address.
My main concern is am I able to choose the extension number for the System Owner? My clients generally like to use range 1000 - 1999 and I always used to choose the System Owner as 5000 in v18. The second part would be why does it not just pull the customers details from what I entered against the license?
We usually create another for us since we manage our clients’ installs. Another for them. Then the original can be removed and the number reused.
Reactions: aaronl
Just edit the setupconfig.xml file with the extension number you want. Dont forget to also change the operator extension too.
Yes. This is what I had been doing. It just doesn't make much sense to me as to why 3CX would have removed something that was part of the setup process previously.
I'll give this a try next time and see if it's quicker and easier then deleting and creating a new extension. Is there any possibility the ability to enter the extension number and name will come back to the install wizard?
Reactions: NicholasP_3CX
