new logon details
Roy Finch
Under the extension and then phone provisioning the web page password is listed in there
For FXS devices you need to go to the FXS/DECT section, select your HT802 and there you will see the "Device Web Page Password"
For regular deskphones its under extension > provisioning as @diamond9 said.
Could it be possible to have the FXS/DECT password show in Phones? Right now it always shows the provisioned extension phone password, which doesn't since it's not the same at all.
It's a bit annoying having to go to FXS/DECT everytime we need a password.
Reactions: AWS2P
This is not something we are looking to change for now.
The FXS/DECT session is handled a bit differently due to the way we provision. Think of it this way:
- Deskphones are assigned under the extensions because 1 MAC can only belong to a single extension (and hence the extension has a device UI password used on its devices that appears on the phones section as tou noted)
- FXS/DECT devices we have 1 MAC with multiple-extensions, so we do it the other way around
I understand. It's just annoying and I'm pretty sure it would be easy to show it but I know there are far more important priorities.
3K8iMGWviZ
