New Static IP - No Calls Out
CISD21
We migrated ISP's last week, and now can't make calls out via 3CX (v18 on Server 2016.)
I updated the static IP within 3CX, which appears to have worked just fine - though I've read I should have switched to dynamic and back to static, so I'm currently set to dynamic.
Our SIP trunk is a Patton SN4171, we've had no issues until now.
If I check the activity log for my extension calling out I see the log message below. (Cell number removed for obvious reasons.)
07/05/2022 12:02:25 PM - Call to T:Line:10000>>**CELLNUMBER**@[Dev:sip:[email protected]:5060;transport=udp] from L:1.1[Extn:1170] failed, cause: Cause: 503 Service Unavailable/INVITE from 10.56.33.5:5060
Any ideas?
Changing the isp wan IP address within 3cx , should not affect the config of the SN4171 as this uses isdn2 lines for phone calls.
is the Patton registered ? , does it affect outbound and inbound calls ?
Reactions: JohnS_3CX
Did you also change your LAN at all, or just your public IP? Where is the Patton in relation to 3CX?
LAN hasn't changed, just our public IP. Both are on our network, sitting next to one another in our data center.
martin1176
