New Yealink T44U phone available
mcsphones
Gold Partner
Hello. The new Yealink T44U phone is now available in distribution. Will 3CX support it in an upcoming update? Relatedly, what existing Yealink template/model should be used in 3CX for testing? Thanks,
I have managed to configure Yealink phones manually and have had a great success with them .Would you like to try this out to test the device? I have checked out T44U but there isn't much documentation even from the vendor to compare the phone it closely matches.
The T43 matches the button layout. I've set one up to work. You can't push a provisioning file to it remotely though, need to reboot the phone each time to get the changes. Sidecar works as well fine.
Isaac415
