Solved NFTables V18 - Port 5062 not allowed by default
Evolute IT
3CX MVP
Gold Partner
Hi guys,
This was something I noticed during the RC stage but it seems it wasn't modified for final release.
When using a 3CX FQDN and Teams integration, we need port 5062/tcp opened. This is easy from the Cloud provider side, but here's an issue:
The NFTables are not opening it. So we need manual SSH access to allow the port every time.
Can this be added to the default setup or, even better, be modified when we enable the Teams integration?
Update on my customer: we rebuilt the system completely but now we did figure out the private key is unable to load.
We will redo the certificate and see if that fixes it.
One more tip just in case, in Settings --> Microsoft 365 --> Teams Direct Routing, in the "Teams FQDN" field make sure you enter the value in lower-case characters only.
That's the first thing we checked.
Hello, I have the same problem, I have opened 5062 in AWS, I have verified with commands nft list table inet and nftables.conf but I still cannot open the port, even though everything seems to be well configured.
Has any conclusion been reached?
First things first, after you have enabled the Teams integration, upload the cert/key, etc, as per the guide, then check that your 3CX is indeed listening on port 5062. You can do this by logging into your 3CX Instance via SSH and run command:
Bash:
netstat -laputen | grep 5062
You should see something like this:
Also make sure you check your AWS Security Group that you are using for your 3CX Instance and that port 5062 TCP is included there as well.
Bash:
Thanks for your comments, I actually followed the step by step, and checking with grep, it is confirmed that 5062 is not listening. I attach evidence.
On the other hand, as I had mentioned from AWS, the ports are well configured.
OK, so indeed the issue here is that 3CX is not listening on the port.
Could you please check the Certificate and Key files you uploaded for times to see if they are are a match?
You can check the instructions here: https://www.3cx.com/community/threa...5062-not-allowed-by-default.83936/post-392253
Also one very important question, the "Teams SBC FQDN" you have entered in Settings --> Microsoft 365 --> Teams Direct Routing tab, is it the same as your FQDN you used during the 3CX installation?
We have the same issue and files are indeed matching.
The cert has the CA and intermediate in it. The private key we tried encrypted and unencrypted.
It just won't load without any clearer error than "failed to load private key".
I'll send you a PM shortly.
To everyone reading this thread, I mentioned it before, but I will say it again and not link to the comment.
Use these 2 commands to validate that the Key and Cert file you are uploading match:
Code:
openssl rsa -noout -modulus -in <path to KEY file> | openssl md5
Code:
openssl x509 -noout -modulus -in <path to CERT file> | openssl md5
The output of the 2 commands must be 100% identical, otherwise you are a no-go.
Important Note:
Most of the Certificate Authorities give you a Cert file, and then a bundle file that contains the intermediate files. As stated, these need to be combined into 1 file.
The Certificate File contents must be at the top of the new file, then the contents of the bundle file below....
Also the above commands should be ran after you have "merged" the cert with the bundle.
Dear, the fqdn is not the same. Here it says to use 5062 if the PBX uses the FQDN provided by 3CX.
