NGINX CVE
de2
Dear 3CX Security Team,
Following the disclosure of multiple critical NGINX vulnerabilities on 18 November 2026, we would like to know whether 3CX installations are affected.
We operate a self-hosted 3CX Enterprise V20 installation on Debian 12 in Microsoft Azure, deployed using the official 3CX image.
As 3CX now maintains its own embedded NGINX version, could you please clarify:
  1. Is the NGINX version bundled with 3CX affected by these vulnerabilities?
  2. If so, when can we expect a security hotfix?
  3. Are any temporary mitigation measures recommended?
  4. Will the security fix be deployed automatically?
Our PBX is internet-facing, so we would appreciate a timely response.
Kind regards,
For the reported CVE's nginx has released an update however this is not yet released from Debian, we are currently checking also on our side and get back with an update as soon as possible.
Thank you for your response.
However, according to your own security announcement from June 2026, 3CX decided to bundle and maintain its own customized NGINX version, specifically to avoid depending on Debian’s security update schedule.
https://www.3cx.com/blog/news/http2-vulnerability-mitigation/
You also stated that this approach would allow 3CX to respond immediately to future NGINX vulnerabilities.
Yes of course as blog post says which give us the ability to make updates without waiting for Debian.
In any case though we need to evaluate fixes before we push any update and not just blindly send an update.
We currently checking and we will inform once there is an update.
Teresa Nguyen
