Night service indicators
Chichi
I have a system where the user manually puts it in to night service using the *711 / *712 codes.
I am looking for one of two things, either a light that show then lit if its in or out of night service.
Alternatively when I dial *71 I get a message saying “phone system is now using the default office hours”. Is there a way to make it say which service its in ?
Thanks in advance,
Scott
I can think of a couple of options. Some phones can programmatically have BLF lights turned on/off. That's one option. Or you could use a device like BusyLight to programmatically turn on/off this programmable light. Or you could write a CFD that when dialed tells you the current status then asks whether you want to change the status (this would require using the 3CX Call Control API).
So nothing simple then :D Gone are the days of the old panasonic KXTD's
thanks for the this. i will look at each option and see what would be best suited.
hughesdouglas
