Solved No Audio between remote extension
groupe10
We moved PBX hosted on 3CX cloud. We do not have audio between every remote extension. Grandstream GRP-2602P firmware 1.0.3.63 provisionned as stun.
Audio are fine with outgoing and ingoing calls but not between extensions. Extensions are on the same LAN . Is there any firewall or port forwardind required on the remote site with phones ?
PBX Deliver audio has been check on every extension
I would save yourself some troubleshooting and install a 3CX SBC. Even a Raspberry Pi, depending on the number of extensions. The audio port range on each device should be unique. Unfortunately, a number of help articles on the 3CX site , regarding STUN issues, that I would have referred you to, have been removed.
https://www.3cx.com/community/threads/stun.65555/#post-280289
Go with an SBC. On stun phones on the same network they are at their worst when you call each other. SBC fixes that and more.
Reactions: Charles_3CX
@groupe10
As mentioned from @leejor and @CentrexJ an SBC will save you the extra configuration both on the PBX as well as the remote site firewall, since when using STUN provisioning each phone must have a unique SIP port and a dedicated RTP port range. Note however that STUN is not a supported provisioning method in the 3CX hosted instances.
mazet
