No audio but echo test working
marche
When using LTE of my primary carrier, I can place echo test calls to the PBX and can hearmyself, but when I call extensions or other numbers there is no audio (ACK does return, the call lasts more than 30 seconds). But when I use another carrier, both the echo test and calls to extensions work without any issues (so it is not a codec issue as I first suspected). So how come using my primary carrier the echo test work but calls to extensions dont? (The extensions are in the same LAN as the PBX).
My first guess, would have been a Codec issue as well. Does the 3CX Activity Log show any sort of error? Any difference, in the logs, of a working. and non-working call?
3K8iMGWviZ
