No audio on inbound and outbound calls
Frank86
We are using 3CX with a Spectrum PRI as the primary provider (which works fine) and Flowroute for a few DIDs. The Flowroute DIDs do not have any audio on inbound or outbound calls. Flowroute is configured as a SIP trunk exactly as other 3CX instances we have (where it s the primary SIP provider). We have a Fortigate firewall, and the firewall checker passes all tests. Any suggestions?
  • 3CX Version, Enterprise Annual 18 update 4 (build 965)
  • Server OS, Windows server 2019 standard
  • Is the 3CX Server Hosted and where? Locally
  • Provisioning Method: Local
  • Trunk Provider or Gateway Make/Model - Flowroute
have you try to check de box PBX delivers audio in your trunk configuration options?
can you make a capture of the invite and post it
Problem fixed. We had to disable NAT on 3CX port forwarding rules.
I also have the same issue (no inbound and no outbound audio) after Update 4 on V18, we are using AWS lightsail cloud base 3CX server.
Please help me
  • 3CX Version
    , Standard Annual 18 update 4 (build 965)
  • Server OS, AWS Lightsail Debian
  • Is the 3CX Server Hosted and where? Cloud
  • Provisioning Method: Stun
  • Trunk Provider or Gateway Make/Model -Telnyx
  • Phone: Grandstrean 1625, 2160
martin1176
