- Joined
- Jan 21, 2020
- Messages
- 8
- Reaction score
- 0
These two are mutually listed as supported, but it's essentially not working at all. Sennheiser Headsetup Pro and the Sennheiser 3CXPhone Plugin are both installed, yet
The computer has no audio hardware enabled beyond the Sennheiser D 10.
- there is no audio reception beyond ringing (which I believe is generated by the headset itself and not an audiostream from the softphone) from 3CXPhone (other applications output their audio to the headset, so it works)
- there is no audio transmission, either
- calls can't be properly accepted by the headset button - the first push while ringing terminates the DECT connection and the second push reconnects and accepts the call in one press for some reason. Disconnecting a call works.
- no outgoing calls can be made (resulting in instantaneous "call failed"; the PBX doesn't log anything so it does not seem like it is even contacted).
