Solved No Dashboard after logging in to 3cx
Firdoshnd
New User
I have installed 3cx on my raspberry pi4 wifi connection and am able to log in using https://192.168.0.110:5001/webclient.(Local) However I do not see any dashboard just one user extension I created during setup? Also when I call this extension from my phone app it goes straight to recording message. Am I missing some steps to bring up the dashboard? Also the outside URL does not work. During setup I choose Dynamic IP as I do not have a Static IP. How does 3cx know when Dynamic IP has changed?
You are not logging into the 3CX management console , the web url is https://192.168.0.110:5001 - use the admin and password account details you created during the installation. At the end of the installation, you would have seen this info on the screen.
Have you configured the required port forwarding to allow access externally - https://www.3cx.com/docs/manual/firewall-router-configuration/
On the extension (operator created during installation) - have you provisioned any device - handset , 3cx app or mobile app. If you have not. then it using the forwarding rule 'If I am busy or my phone is unregistered, forward calls to:' to forward to voicemail.
Reactions: Firdoshnd
Thank you for your assistance I managed to log on to the Dashboard now and will configure the port forwarding as per your instructions.
Reactions: VasilisV_3CX
Great job @Firdoshnd, feel free to open an new thread if you require anything else!
