No longer red/green indicators in new version?
lloydr1l
In earlier versions, one could watch the Trunk and Extension dots to see activity for them and the Ring Groups involved, etc. It was a very simple at a glance indicator of the flow.
In the new version, the dots do not change. Is there no longer a way to visually see this type of activity? I know I can go into "Number of calls in use", but it does not appear to show Ring Group activity.
So if I'm looking to see if all needed extensions are ringing in a particular group, I don't see that any longer. If not, very surprised this has been taken out.
Hello @lloydr1l
Please note that this is no longer available in V15. As you mentioned the "Numbers of calls in use" is a good way to keep an eye active calls or you can use the Web client and the switchboard to do the same.
Zexus
