Solved No ringing after a person finishes a call while there is an incoming call.
M4rtin
Forum User
Hallo,
in my 3CX is a ringgroup with 2 members. The problem is, if A is in a call and B doesn't accept a new incoming call, then A finishes it's call and want to take the new call but it is not ringing on A's phone, only on B's phone.
Thanks!
Try using a Queue
Ring Group calls will not re-poll an extension if the extension became available after the call has already started ringing. That said, you should either use a Call Queue as complex1 mentioned, or, the user can actually pickup the call manually by using the call pick-up feature by dialing *20*RG_EXT where RG_EXT is the Ring Group extension number (example: *20*801)
Note: The default dial-code for call pickup is *20* but yours may be different. You can check what it is under "Settings >> Dial-codes".
OK I'll configure my Call Queue get calls directly and not only if the ring group is not available. Thanks!
Reactions: ChrisC_3CX
You're very welcome! Please feel free to start a new thread should you need additional information or assistance!
devo.it
