Solved No SIP trunks will register
jm34
Yesterday something happened (unfortunately I can't figure out what yet) and all of my SIP trunks don't register anymore.
We use Flowroute, CallCentric, and a local Patton trunk.
I have tried registering based on IP, and the Patton has always been set up by IP. I'm currently at a loss as to why none of the trunks will register. I even tried to install a brand new 3cx instance (on premise for both). I did restore a backup from a couple days ago during the setup process, but it was from when the system was working. Both have the same results of no sip registration.
The Patton and the 3CX server are also both plugged into the same switch.
I can ping/resolve all of the services/devices from the 3CX Debian console.
Suggestions as to what to do next.
What is your OS? have you checked firewall/AV software on that?
Debian version 12 (3CX ISO install)
3CX Version 20.0 Update 3 (Build 806 Release)
Have you restarted? Turn up the logging and review logs.
10/24/2024 9:08:05.491 AMLc:10001(@patton V2[<sip@:0/UDP>])Failed to create device
10/24/2024 9:08:05.491 AMLc:10001(@patton V2[<sip@:0/UDP>])Creating master device
Resolved. Network config issue.
parik24pro
