No voice from my ip phone
ashwingorityala
SMB User
I've successfully registered and Provisioned the phone, but there is no voice on both sides
Phone: yealink T31G
  • 3CX Version, 18.0 (Build 315)
  • Server OS, WIN 10
  • Is the 3CX Server Hosted and where? On-premises
  • IP Phone Make/Model/Firmware version, e.g. Yealink T31G version 124.86.0.40
  • Provisioning Method: STUN
  • Trunk Provider or VoIP Gateway Make/Model, SIP-Trunk
  • No VLAN configured
Account gets registered on the IP Phone, calls are working fine, but to voice
See your issue, you have configure the phones as stun , as the phones are on the same network as the 3cx server you need to use local
Delete the phone configuration within 3cx , under users , provisoioning - select the phone and delete
factory default them and follow the steps from 3 in https://www.3cx.com/sip-phones/yealink-t32g-t38g-t42g-t46g/
Make sure the phones are running the correct firmware, links in the url posted above
I'm trying to config telephone outside the network
If you do not have control over the firewall on both the PBX side, and the phones side, don't waste time on STUN.
Just install an SBC as mentioned above and it will make your life a lot easier.
Stephan Eusebe
