No welcome mail or notification mail is going
vipul zala
Forum User
when i tried to test smtp i am getting error : unable to read data from the transport connection : An existing connection was forcibly closed by the remote host.
please help....
Hello @vipul zala
Are you using a custom smpt server or the 3CX smtp server?
Hello @vipul zala
Hello YiannisH...thanks for the reply
well pardon my half knowledge i did not get your question
but i tell you what i have in my office ... we have configured 3cx in our server & i used to manage it via admin panel it was all working good till one day i came know that we are facing problem in outlook that smtp port number 587 is not working so i changed the port to 465 in every outlook but then from that day i noticed that no one is able to receive 3cx notification and i m also not able to send welcome mail
i did everything i have checked my fortigate router as well but nothing was there & then i talked ISP they said nothing is block from their end....
& yes one more thing we are using gmail account as mail server to receive notification & welcome mail ...
There is a 3CX SMTP server you can use to test the system. Just navigate to Settings / Email and pick the 3CX SMTP server from the drop down menu. Please note that if you are using a standard version you will not be able to revert back to your own SMTP server.
sir, why i didnt get welcome mail ?
Are you using a custom SMTP server of the 3CX SMTP server? Does the test email work? Is the email under extensions settings correct? Did you press the "Send Welcome Email" button?
